Originally Posted by P's Titan
He said a slip light comes on, isn't that the VDC ? When I turn it off and peel out around a corner that light does not come on. When the VDC is on the slip light comes on and it brakes to were it is slipping.
Please respond if I still am "confused"
According to the manual the slip light will come on if either the ABLS or VDC is engaged. If you have ABLS the slip light should come on if you have one wheel spinning. I have had the ABS replaced in both of my Titans because they either wore out(first Titan), or was bad from the factory(2nd Titan).My ABLS is engaged(slip light on) about 10 times a day while driving on the ranch. Sometimes for 30 seconds or more at a time.
Also, on my 04 the light said BSLIP, while on my 05 it just says SLIP.
