Old 04-05-2006, 08:51 AM   #17 (permalink)
helomech
helomech's Avatar
Re: what am i missing out on? 4x4 texas edition what options am i missing?
Originally Posted by d0va
im sure is 4x4 i have 4hi 4lo knob next to the ignition switch and no idont have another switch i only have the tow mode in the middle by itself. so what is that i have ABLS only? pls help...im confused what about the e-locker? what is it for
Yes you have the ABLS only, anytime one tire is spinning and the other is not you should get the slip light. The e-locker locks the rear tires together so one can't spin without the other, it only works in 4Lo unless you mod it. You should not need the e-locker unless you are doing lots of off roading or climbing at weird angles.
