Re: Welcome to the New Towing and Hauling Forum!
Originally Posted by TitanVT
OK so I have a question.. While towing my 25' 5th wheel if I drive in 4th with
tow mode on, the truck shifts down to 3rd on the hills and I have all the power needed to pull the hill and then some, then if I lift a little bit it seems
to shifts to 4th where it pulls good with less reving then it seems it goes to 5th when the RPMs get to about 2700 then kicks back to 4th after it lugs in 5th and back and forth it goes until I lift and put it in 3rd and and it revs to about 3000 rpms or so.. lost yet? so my question is I thought "Tow
mode" locked out 5th gear.? then I tried pulling a hill in "D" and it shifts to 4th
and pulls real good but the tranny guage goes right up.. does the " Tow Mode" do anything? Seemd like to much shifting going on.. anyone else notice
this? or should we just stick it in third and go for it? and how long till we smoke the tranny?
Do not tow in 5th it will overheat and wear out your transmission. Tow Mode does nothing but adjust shift points at higher RPMs for more "pulling power". Tow in 4th and if you notice that the torque converter is locking and unlocking (feels like a half shift) or the trans temp is rising shift into 3rd.
2004 Nissan Titan KC SE 4x4 with Big Tow package- Zoomers exhaust tip, Rear-view screen in sunglass pocket, scanguage intergrated into overhead console, power tailgate lock.
1982 Delorean DMC-12 Turbo (Vin #10696)
2000 Toyota Camry CNG Powered
1999 Forest River Sandpiper 21R 5th wheel trailer
