Originally Posted by tillery444
It is a 98 4x4 Montero I had the brakes inspected & was told that I need to Replace the front rotors & pads and resurface/turn the rotors and replace pads on the rear. Pep-boys wanted like $563.00 & sears wanted like $480.00
Mike
I am sure that I can help you do all that for less than $100 unless the rotors need replacing and in most cases not.
The going rate is about $400 for all 4 in most shops. Are there drums brakes on the back?
