Old 04-21-2006, 10:30 AM   #50 (permalink)
Armada
Armada's Avatar
Re: Double solution VS Axle-wrap
Originally Posted by Ramon
Would this type of setup be benificial for towing. I own a 04 Armada with a new rear end at 10,000 miles. I also own a 05 Titan that I now use to tow my camper with instead of my Armada.
Ramon, our Armadas have coil springs and an independent rear suspension. You probably also have the air bag suspension levelling system if you have Big Tow. This set-up will not work with our spring system.
If towing capacity is the issue, I'm not sure this type of setup would help with the Titan. Maybe. It's not axle wrap at issue there, but rather "squat." I've not studied the diagrams and drawings, but it might help somewhat. "Helper" springs for towing purposes usually go on the back half of a leaf spring setup.
A weight distribution hitch would probably do you more good -- if you are not using one and you are towing heavy, start with that, because you really do need one.
'04 Armada SE Offroad 4x4
Galaxy Black
K&N Drop In Air Filter w/ airbox mod
Carbotech Bobcat front brake pads at 28K miles (no brake judder, just time to change pads)
Armada is offline   Reply With Quote
