Old 04-22-2006, 11:23 AM   #1 (permalink)
sculver
sculver's Avatar
Towing In "D" versus "4th" Gear w/Tow Mode
Okay Titan owners, can you handle one more dumb a$$ question about towing? I’m a new Titan owner and just picked up my boat out of winter storage. It was about 45 miles back to home and I had a couple questions about the tow mode and automatic transmission.
First, I have a 2006 Titan Crew Cab with the tow and off road packages. The boat weighs about 4200 lbs. total (boat, trailer, fuel, toys, etc.).
When towing with tow mode on and the gear selector in “4th” (O/D off) I’m running about 2200 rpm at 65 mph. When towing with tow mode on and the gear selector in “D” (O/D on) I’m running about 1800 rpm at 65 mph.
I understand the tow mode does nothing other than alter shift points for greater acceleration when towing. It seems to do that just fine. I guess my real question is, does it hurt the transmission to tow in “D” with the tow mode on if the transmission is not shifting back and forth between O/D and 4th gear? Is the 5th gear too weak to tow 4200 lbs. on the highway?
Even on small to moderate hills the engine never down shifted while in “D” and towing the boat. I’m sure this is attributable to the outstanding 379 ft./lbs. of torque this engine produces down low in the rpm range! The transmission temperature gauge never got more than half way while towing the entire trip (it read the same as when I'm not towing).
This is my first season towing with the Titan and I wasn’t sure about towing in “D” versus towing in “4th” with the tow mode on in both cases. I appreciate everyone’s expertise that has much more experience towing with their Titan than I have. Thanks.
Regards,
Steve
2006 Nissan Titan SE Crew Cab 4x4 Red Alert
Big Tow, Off Road Package, Utility Package
Mods: Tinted Windows, Truxedo Lo-Pro
sculver is offline   Reply With Quote
