Old 04-24-2006, 01:01 PM   #4 (permalink)
scsTiTan
scsTiTan's Avatar
Re: Gauges ALL DEAD!!!
I don’t know if this helps or not but when I was doing my radio install as I was setting things up with the stereo on but not the ignition, it drained my battery pretty quick and when I went to start the truck my gauges went crazy - like negative readings and needles bouncing around - you might check out your battery.
Also if you have anything plugged into your ODBII plug you should unplug that.
Just some ideas, hope you get it worked out, be sure to let us know what the problem turns out to be.
Steve
Steve
09 CC LE 4x4
MODS: DR Front CO w/ PRG UCA's and spacer, Radflow Rear shocks
Kenwood DNX 8120
SOLD
04 KC LE 4x4(BT/OR)
Super Fast Silver
scsTiTan is offline   Reply With Quote
