Old 05-08-2006, 09:40 AM   #34 (permalink)
QWIKWHIP
QWIKWHIP's Avatar
Re: How-To:Getting a pre amp signal from OEM midline 6-CD stereo
Originally Posted by twtitan
well i was with a friend of mine today we took the hu out and put the rcas in hooked it back up and lost more power than the lc6 we had hooked up.and we still have alt. noise.when we had the lc6 in you turn the knob up to 15 it was pretty loud.with the rcas you turn it up to 15 and it was alot lower .what is the deal
I don't know man, mine works 10x better than when I had my PAC LOC hooked up. And I have zero noise. I did another Titan a few weeks ago and he had alternator noise too. He had an old Fosgate amp and wanted a new one anyway so he bought a new Alpine and we swapped it out this past Saturday. We also moved the ground to a seat bracket bolt instead of on the back wall. He now has zero noise as well. So if you have good amps, try a different ground. As for the volume, you have to remember this is probley only a 1 volt or less preamp signal, so maybe that's what your experiencing. The stereo goes up to 31, and you generally want your loudest clean setting to be 3/4 volume, which is about 24. Mine hits loud and clear on 24 and I can go up to 26 or 27 before I hear any noticable distortion. I think you are just used to your LC6 giving you your volume at a lower number is all.
