Originally Posted by pi3yeargrad
so what do we gotta do to add some spray in our trucks? also, would we use wet or dry? any kits made special for the titan or any would do? any reccomendations?
First I would reccomend to read through this thread:
Nitrous thread
Second you need a dry/wet kit and a fuel rail adapter as mentioned above if goin wet.
Third you need to pull your stock plugs and go with the Denso or NGK iridium plug 1 step cooler. You can get these at Sparkplugs.com
Fourth it's a good idea to get a A/F Gauge. Dyno tune has one for $279.
Fifth buy the Cipher software so that you can retard timing (-2) if needed and so you can data log your runs.
Sixth have fun doing the install and or pay someone to do it...around $300. The installation is not hard to do just a little time consuming because theres things to think about liek where does the line run, where does the bottle go, do you want to hide it etc.
As you might can tell I have been thinking about this mod for a while and I soon will have all my parts just gotta get it'R done.
