I was several hundred pound over GVWR with the setup in my sig. The only problem I had was with the soft suspension. I wouldn't sweat it. If you find you have too much bounce or you bottom the rear on occasion, install a set of
Timbrens or a set of
air bags and you should be set. I should add, however, that exceeding the axle ratins should be avoided. Good luck!
