Re: Greg strikes again!!!!!
I put mine on today. Took more than 2 hours though. Still don't see why Greg suggests taking the sway bar attachment off. Did not see where it helped. The instructions do not tell you which attachment to remove. Since one nut was seized I removed the lower nut on the ball joint on one side and the upper nut on the other. Did not think it would make a difference but with the lower nut removed I had much better access to the strut bolt. BTW - the spindle bolt is 22 mm.
Overall it looks great. Off to get my alignment.
