Old 06-07-2006, 07:50 AM   #5 (permalink)
O4DRUNNER
O4DRUNNER's Avatar
Re: Bcm Module Sub-harness Info
Originally Posted by bgcntry72
Took me about 2 hours under the hood, bed, and dash before I found those fuses hidden in the holders.
Had everything on the trailer but left stop/turn.
Shredded my hands testing every fuse in the block under the hood, and then started unplugging and plugging around the rear of the truck.
Finally decided to take the brake controller out of the mix by unplugging the harness, and saw those 2 fuses.
I smoked a cigarette and drank 3 beers in frustration and celebration before I changed that piddling mini 10a fuse.
Bastards.
Now you see why you need to sit down with a few beers and an hours worth of time to do a search on Titan Talk......Sorry i had to poke at you a bit.
O4DRUNNER is offline   Reply With Quote
