Re: when using aux input, sound only on driverside
Try using another mini jack plug. Just sounds like the contacts aren't touching for your right channel. Wiggle it and make sure it's fully engaged. If that doesn't help, then you might have wire disconnected. It's easy to pull off the bezel and check.
-Counsel Yourself
2009 Blizzard Pro-4X
