Originally Posted by m95roadster
Good job! Your times are improving. Are you running with the 22's?
Yup. I also lowered the pressure on the right rear from 40psi to around 37psi. Its the only wheel that spins and pulls the TITAN out of the hole so hopefully it helped out. Since they are radials...not slicks, I don't need to drop it to a uneccessary 25psi or some really low pressure.
