Re: Where's My Bass?
You can keep the RF HU, NAV & replace speakers & sub & amps and have a decent system.
I used a Navone 4 channel LOC, Scosche NN03 & NN03 R harnesses, an Audio Control Matrix pre-amp, 2 sets of edesign components, a couple of amps, a capacitor, an Optima blue top battery, a 200 amp alternator, & some sound deadening. With an 04, you can make an amp rack for the rear cab wall as there is no power rear window mechanism in the way.
Check Sammy Sandbags gallery for photos.
JL audio has a stealth box with two 10's that should be fairly easy to install if you are looking for an easy solution to just add bass. I think a problem with just adding an amp & subs is that you may have some sheet metal resonating w/o adding sound deadening.
