Old 07-03-2006, 07:57 PM   #10 (permalink)
04RamHemi
Re: TruTrac Titan V.S. 96F Heat @ the track
Originally Posted by Toomnymods
I have to go thru it they have barrier walls on both sides and no room to go around it.. Even if I did want to go around it I wouldn't be able to do a burnout with posi traction with the KDW tires they grab like no tommrow, the water was the only thing that let me get my tires hot enough to do a burnout. On the street my truck gets good traction but usually for some reason the rear wheel hops which is getting rather annoying..
Oh, well if you can't go around it, then nevermind. In regards to your wheel hops, have you lowered your truck or done anything to the rear suspension? Do they make traction bars for your trucks. They make them for the Ram and it' pretty reasonable, about $250. Pretty good time anyway considering the conditions.
04RamHemi is offline   Reply With Quote
