Originally Posted by Toomnymods
I have to go thru it they have barrier walls on both sides and no room to go around it.. Even if I did want to go around it I wouldn't be able to do a burnout with posi traction with the KDW tires they grab like no tommrow, the water was the only thing that let me get my tires hot enough to do a burnout. On the street my truck gets good traction but usually for some reason the rear wheel hops which is getting rather annoying..
Just try to get the water off the tires! Don't do a long burn out and over heat your tires! You only do that to drag tires.
