Re: Nitrous installed 1st spray today
Just so you all know... I myself have never used nitrous either. However I can tell you that if you wanted to run it with this setup you can. So far it runs rich according to Cipher those files coming later today of the 0-75mph. I'm running a conservative system and may eventually run it harder. But for now 50shot (36N/21F) 87 Octane and stock plug gap on iridium NGK and stock timing is running good even in the heat of Summer.
The bottle is mounted behind the rear seat in my crewcab passenger side much like "the Heads". As a matter of fact I have some of his parts...grin Someone had to carry the torch ya know...LOL
I used the large ars vent opening on the rear wall to slide the braided line and the blow down tube to outside the truck. Instead of a normal style blow down tube and the angle to get the tube outside I opted for a 1/2" coated stainless flexible gas line 36" in length for your home gas appliances. Works awesome.
The Cold Fusion "Wet Kit" I got was a universal but I did need to buy longer hoses from solenoids to nozzel. I'm not quite sure the exact price of everything as I have been pieceing together for over a year while also reasearching the ins and outs of running NOS gas on autos and nissans.
What I'd like to do is approach Cold Fusion to see if they would offer a kit based upon mine to sell so that all the pieces are the right length and everything is there.
However for pricing lets say:
NEW CF Universal Wet Kit $470
NEW NyTrex Nozzle $70 Nozzle Adapter $22
NEW NX TPS $99
NEW NOS Heater $270
NEW Flexi-Blow Down tube $21 Ace hardware
NGK Iridium Spark Plugs Stock and one step Cooler $125Assorted wires, connectors, fuses, relay and switch $70
Nitrous fill up $4.50/lb.
Assorted Jets need two Fuel/NOS $6ea
Assorted Bottle fittings $30
Stillen Fuel rail adapter $50
Professional Installation $250-$400
If you have a Volant the nozzle screws in really nice and firm to plastic tube. Some of the stuff you can buy used and spent time at the LS1 buy sell forum.
I have a MSD digital window switch and Tach pickup that I'm not thinking I willl need since the NX TPS switch is doing a great job of keeping things safe. However if that reflash from Techno or Uprev finds its way to me then I might need it for sure.
Oh and thanks for teh comments on setup however my engine bay is dusty dirty.
