Nissan Titan Forum - View Single Post - Wheels, Tires, and Offset (master list coming!)...
Old 07-26-2006, 04:38 AM   #23 (permalink)
kcchief_fan
kcchief_fan's Avatar
Re: Wheels, Tires, and Offset (master list coming!)...
On the left side you can input stuff in inches like 35" x 12.5" tire on a 17" X 9" wheel with 4.5" of Backspacing and it comes up with a number in bold red that will say "no rub", "no rub with a level kit", "no rub with a 6in lift", or "rub". obviously I didn't talk about taking off mud flaps, pinch welds being bent, fiberglass fenders, difference between 4x4 and 4x2 or with or without offroad package as I couldn't find enough data to get that specific. The right side is if your tire is metric i.e. 295/70r17 and offset is in metric i.e. 30mm the wheel size is still input on the left but automatically draws it to the right. I also have a row for original config so you know how your new or proposed setup compares with the final number. That final number is technically the distance (in inches) from the center (x, y and z axis) of your hub outside mating plate to the edge of the tire (outside rear edge) that would hit you back inside front fender. I didn't take into account any deformation of a loaded tire or the oddity in tire size by each manufacture. I just used trig and alegbra to get the theoretically distance and looked at what people said was and wasn't fitting and comparing it to my numbers that were generated. Overall it is statistically close. Backspacing was determined (after looking at a few wheel manufactures that calculate both backspacing and offset for their wheel) by saying that both "lips" on the wheel equal .92". Obviously not every wheel manufacture has the same lip size and that is why backspacing is not the best measurement to use to compare tires amongst manufactures for clearance issues concerning the tires. However it is a great measurement to determine clearance issues with the wheel to stuff like sway bars and knuckles and such.
2005 Crew Cab LE 4x4, Born on Date 5/05, Adopted 6/05/05, Smoke, OR/BT Packages, Sunroof, Nav System, DVD System
Mods: RETRAX Bed Cover, LUND SS bug deflector, AVS window deflectors, Covertech leatherette seat covers, ATS Fender Flares, LLumar ATR 15 CH SR HPR front side window tint, Valentine V1 radar w/ remote view, GTech RR, NAV speed sensor override mod, Power Tailgate Lock, SilverStar High Performance Halogen high/low bulbs, Injen CAI, Active Tuning Grounding Kit, ProComp Stage I 6” lift kit, Chaos Upper A-arms, Radflo 2.5” reservoir raised truck coilovers, PRG street traction bars, Deaver 2” mini-pack w/ 1" billet block, Bilstein 5100 rear shocks, CST sway bar extensions, Toyo Open Country M/T 35X12.5R18, Gear Alloy 711MB 18X9 off 10mm, Bassani exhaust, UpRev Tuner
Wish List: Bull Bar, Grill Insert, Clear taillights, Backup camera, Header, Stillen Supercharger, Tailgate chrome Bib, HID headlights, Amp Research Power Steps, Nissan Ipod controller, Larger crossdrilled rotors and ceramic brake pads, AVelectronics video switcher
kcchief_fan is offline   Reply With Quote
