Originally Posted by BKW
It's easy for me to see why all of you are having rear end problem. Jacking the truck up, with or without offset wider wheels changes the geometry and puts a BIG strain on the rear end and suspension. The truck was not designed for all these mods, which look neat, but cause big problems down the road.
When I worked for Ford Parts and Service (1962-1995), any geometry changes including wide wheels and tires, or jacked up to the hilt voided the warranty. How can you expect Nissan to cover problems brought on by things you did to mod your truck?
My seal was leaking before I added any lift to the rear, only the front was leveled. I run OEM rims, and when I replace the tires I selected the stock size 285/70/17.
There appears to be issues with the design of the breather element, and it affects stock Titans too.
And btw, Nissan gladly replaced mine, and didn't even ask/worry about the new lift. I would guess that is another good reason to buy a Nissan instead of a Ford. Looks like you did, so that says a lot.
