Re: Travel Trailer Hauling
There will be people on here that will tell you that you will be fine but you will regret it. What you are looking at it to much for the Titan. I would be more concerned about the length then the weight. On a flat area you would probably be fine, but going up a steep grade with a cross wind and a semi passing you will give you white knuckles. Just my opinion. Look at the post prior to this one about the FS2500. You will be in the same situation.
