Old 09-02-2006, 10:33 AM   #159 (permalink)
whiteLE
Re: Here's # of Rear Diff Failures Reported
Cheif
If you know how to pull the number of failures by year from NHSTA, will you post it here?
Also, a co-worker with an 04' Titan (4x4, no BT or OR, never towed with) had a leak out of bottom of his cover. He looked at the axle ends/brakes and had fluid everywhere. The dealer replaced the axles and I assume the rear end is part of the axle assembly. He was less than 5K from his warranty running out.
white
whiteLE is offline   Reply With Quote
