Old 09-05-2006, 07:59 AM   #3 (permalink)
PrerunnerGreg
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Re: New guy, which lift system should I go with?
I can get you about 8-9" of lift with a properly set-up Fabtech or CST kit. about 7-8 from a procomp kit. THe Fabtech stage 2 kit has similar propblems that the pc stage 2 does but thier coilovers are very expensive for the lack of performance but you will get the height. Be carful woth the FT kit to not over-extend the upper ball joint as the kit has a tendency to smach the lip of theupper a-arm into the new spindle and loosen the ball joint.
