Re: Quick Question with RF sytem - Upgrade?
Thanks for the input, I definately see what you mean..... so, what if i use an existing afterkaroet 4 channel amp that i have to drive the stock speakers, is that still risky being that they are 2 ohm?
And in both cases if I use the aftermarket amp, and/or new speakers, do they make a wire harness? Or the harness would still be using the speaker signals that is going through the stock RF Amp eh? Therefore would have to run new speaker wire leads from the door, dash, and rear door to the amp or HU if i ran off the HU amp?
Thanks
