Old 09-09-2006, 11:55 AM   #1 (permalink)
markislive78
markislive78's Avatar
Help! Shailey, RB and fellow tuners....Primary O2 voltage question!
Fellas...I'm goin crazy here and need some help. My main O2 Banks are getting different voltage readings, but my fuel trim for both banks look same. Bank 1 Primary O2 shows an average of only half the voltage reading as bank 2...the kicker is that they both increment at the same time/rate just at diff levels leaving me to believe they are working some what. What determines you air/fuel ratio, Fuel trim or primary O2 voltage readings? I am just trying to make sure I don't have an O2 sensor problem before getting a tune or my ECU adjusted for my mods. I don't want one bank to be running richer or leaner than the other before tuning. Does yall bank 1 and bank 2 primary O2's differ or does yall primary o2 voltage readings run neck and neck unlike mine? RB you might be able to tell with Cipher. Should I even be worried?
Thanks a million!
markislive78 is offline   Reply With Quote
