Old 09-24-2006, 03:49 PM   #54 (permalink)
Herbpov
Re: Rear axle seals leaks. Please report.
Originally Posted by ucf_motorcycle
Mine is leaking on passenger side. Its all over the inside of the wheel.
I got 77,000 Miles so no warranty for me. Anyone know how to replace these seals? Any special tools needed?
I would check with the service manger first. This is a wide spread problem and just maybe you could get a goodwill repair. I think someone said the cost is around 400.00. That's why need to get these all reported. We need a recall because it could be a safety problem. Wheel bearing has to be drilled off and a new seal and new bearing pressed back on.
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
Herbpov is offline   Reply With Quote
