Old 10-03-2006, 12:13 PM   #33 (permalink)
justrich
justrich's Avatar
Re: Removing the Sway Bars and Flipping the Coil Bucket for an Added 1"??
Originally Posted by kartman
That depends on your perceptions and wants. I liked it better. It takes about 3 minutes to try out. Remove one swaybar endlink fron the truck and drive it around for a couple days. If will feel wierd at first so give it a fair shot. If you dont like it reinstall the endlink, if you like it remove the bar and other endlink
i just want it to handle off roading at high speed better and jumping but not high just a foot or two of the ground. i like my truck not having alot of body roll and im sure that will increase without the sway bar. i guess bottom line i need to try it to see if i like it. my only question is that will this be a bad thing to do when i frequently load 3 dirtbikes in the back which will make the center of gravity higher. i assume it will have a ton of body roll with bikes in the back but will that be a problem at about 40-50mph on dirt roads in mojave, california city. again i will probably have to try it to find out but if anyone has similar experiance please do share. im also still interested in getting another inch out of the front end without hurting performance. im hoping someone tries this mod and shares. i would try it my self but i dont trust my skills on suspension. also not to sound dumb but it seems to me that you could just use a 2inch spacer insted of the 1inch that the kit comes with. im sure there is a valid reason no one has tried or mentioned this but i dont know just an idea.
justrich is offline   Reply With Quote
