Re: 6" procomp lift, 18" stock wheels, pc 35" xtreeme tire question
It will probably fit with that lift but there are large variables, primarily the backspacing of the wheel. You may have to trim the fender liner and/or cut the pinch weld with the wider tire. I run Toyo 35s which are really like 13-13.5 with only 4 inches of lift but I cut the pinch weld, removed the liner and have glass fenders.
My best guess is that it will fit with very minor rub at full oick with no trimming and no rub with minor fitting, but its only a guess.
Rebar Wrangler
