Old 10-10-2006, 11:23 AM   #5 (permalink)
KYDeepwater
Re: Different Oil Help Cold Tick
The $85 includes the air filter, 7 quarts Mobil 1 5W30, 3 quarts Supertech 75W140, oil filter, injector cleaner. It has worked for me. Any oil that meets the SAE specification will work as long as you change the oil regularly.
We had a guy here at work who had one of the orignal Dodge Caravans, 4 cylinder. He used Mobil 1 and changed once a year in November, then changed his filter and topped off in May. He did about 22,000 miles per year. When he sold the van to his brother, they did a compression test, and the worst cylinder was 96 % of new, at 140,000 miles. No work was ever done to that engine, except maintenance. If it works on an engine like that, it has to be good for one that was put together way better (ours) than a Dodge 4 cylinder.
KYDeepwater is offline   Reply With Quote
