Old 10-23-2006, 12:56 PM   #92 (permalink)
FlimFlamMan
FlimFlamMan's Avatar
Re: Rear axle seals leaks. Please report.
Originally Posted by trkconvert
I had my Truetrac installed a couple of weeks ago and I had not noticed any leaks before the install. So I got under the truck yesterday to change the rear diff oil and saw leaks on both sides covering the rear brake assemblies. Now I understand that I have the seals leaks BUT could the installation be the cause or it is simply a coincidence and this would have happened anyway?
It is possible that the shop that installed the TT did not clean the area up after installation (that was in my case). To be sure, I would wipe the area clean and check it frequently. If it starts showing up again then it should be fixed.
The manual says that the seals should always be replaced when the axle is pulled. However, this is a known problem with Titans. When I take mine in I am not going to say a word about the TT. I'm going to say the diff is fine... fix the seal. Warranty work, imo.
2007 WRX TR (5 speed)
Stage I
The Titan will be missed....
2005 XE CC 4x2
QX56 OEM Wheels
Uprev Tuned
