Old 11-04-2006, 07:50 PM   #3 (permalink)
Smoke05
Smoke05's Avatar
Re: What is the right way to tow?
Originally Posted by Ramon
I have a 04 (XE) titan without the big tow package. I tow a Forest River Surveyor SV264 dry weight of 4053lbs with no problem at all. The owners manuel says to drive in 4th gear. I have alway used 4th with the tow mode on. I would highly recommend you change your rearend fluid after every couple of trips.
Why on earth would you change rearend fluid after every couple of trips? That is expensive and nuts considering the Titan runs synthetic fluid that doesn't breakdown and has a much longer service life than nonsynthetic. Doing a change in the first 5,000 miles to get rid of any debris that may have worked itself loose during break in I could understand. If your worried about potential failure, stop wasting your money on fluid changes as that is not the problem.
Smoke05 is offline   Reply With Quote
