Thread: noise
Old 11-15-2006, 01:01 PM   #14 (permalink)
skyhammer
Re: noise
This may help some of you guys. I had a terrible squeak, but it was hard to narrow down where it was coming from. Sometimes I thought if was coming from outside, other times from the door or the dash.
These pictures are from the passenger side. You remove the glove box as if you are going to change your cabin filters. These same bolts are also on the drivers side, but all you have to do is remove the rubber plug for access.
I was able to get about two good turns with the ratchet to tighten them up.
Close up view, socket is on on the lower bolt.
2007 Tundra Limited DC 4X4
5.7L,NAV,TRD,TOW
Xlerator Exhaust
aFe Stage 2 CAI
Desert Sand Mica
skyhammer is offline   Reply With Quote
