Old 11-24-2006, 12:19 PM   #1 (permalink)
Kyle@stillen
Supporting Vendor (Gold)
Kyle@stillen's Avatar
November/December 2006 Specials!!!
STILLEN Titan Big Brake Kit $150.00 OFF!
From now until the end of the year, the STILLEN Titan / Armada / QX56 Front Big Brake Kit is on sale for $150 OFF! Our kit features 51mm dual piston calipers, made of cast steel for added stiffness, and massive 14" two-piece cross-drilled and slotted curved vane rotors. This kit comes complete with high-performance brake pads, DOT approved stainless steel brake lines and all the necessary hardware for installation. The kit is designed to work with the OE Master Cylinder and ABS system. Now your truck will stop with an aggressive bite and no fade. Perfect when hauling your gear or just plain hauling! Due to the massive size of the 14" two-piece rotors and calipers this kit requires 18" or larger wheels. Please download a Brake Profile to check for fitment. The factory Nissan 18" wheels will accommodate this kit. Our most popular kit , on sale for only $1245.00!
2004-2007 Titan / Armada / QX56 2-Piston 2pc 14" Rotors Big Brake Kit with Red Calipers, Part #30-5600R
2004-2007 Titan / Armada / QX56 2-Piston 2pc 14" Rotors Big Brake Kit with Black Calipers, Part #30-5600
STILLEN 2004-2007 Titan 2WD Rear Lowering Leaf Springs
Bring the rear end of your Titan down approximately 3 inches with the new STILLEN Rear Leaf Spring Lowering Kit. This will improve the appearance and handling of your truck, as well as level things out. These springs are a direct replacement for the stock rear leaf springs. An easy upgrade for those that don't want the "raked" look of the factory ride height. Introductory price for the pair is only $587.00!
2004-2007 Titan 2WD Rear Leveling Leaf Springs, Part #STI04TITAN3
2004-2006 Titan Upper Billet Grille with Urethane Shell, $40.00 OFF!
Or Order the Upper Billet Grille with Shell and the Lower Billet Grille for $90.00 OFF!
This setup easily incorporates a one-piece main grille into the front of your Titan. The shell comes unpainted so that it can be color matched to any truck, from factory to custom. Get this striking look with factory fitment.
Usually priced at $269.00, for a limited time the sale price for the Upper Grille and Urethane Shell is $229.00!
Or order the kit and get the Upper Billet Grille and Urethane Shell with the Lower Billet Grille for $90.00 OFF! Only $259.00!
2004-2006 Titan Upper Billet Grille and Urethane Shell, Part #GR8520
2004-2006 Titan Upper Billet Grille and Urethane Shell with Lower Billet Grille, Part #GR8530
Kyle@stillen is offline   Reply With Quote
