Re: replacing front door speakers ..........
No you will need to remove all of the door panel. Becarefull because its in about 3 pieces that are bonded together. Try no to pull on it to hard its better to just pull gentilly around the out side to release the clips. It has screws behind the door release handle and up at the arm rest and handle. Its not hard. I have taken mine off many times. Good luck
- White 06 KC - ProComp Stage 2 lift - Deavers Out Back - K & N Intake - Cherry Bomb Exhaust - 18" Incubus Offroad Chrome Wheels - 35 x 13.5 Toyo A/T'S - Custom Traction Bars (Thanks Aquaholic) - CST Sway Bar End Links - Optima Yellow Top D35 - Jensen VM9022HD - Pyle PLTVATSC1 HDTV Reciever - Farenheit 9" Overhead DVD PLayer Monitor - Sony 4 Channel Amp - MA Audio 6929 & 5029 Speakers - 20% Tinted Windows - Spaw Power Windows And Door Locks Kits - Prodigy Brake Controler - Stillen Brake Booster Support -
