Old 12-01-2006, 05:46 PM   #4
adavis99
adavis99's Avatar
Send a message via AIM to adavis99 Send a message via MSN to adavis99
Re: Best of Titantalk
Frequently Asked Questions:
What is the difference between VDC and ABLS? What are they? How do I turn them off? What do they do?
VDC: Is designed to keep your truck moving forward as opposed to sideways. It's an "intelligent" system that does some complex things. If you have this, you have the option to turn it on off via a button in the center/bottom of your dash under the a/c knobs next to tow mode.
ABLS: This applies brakes to a slipping wheel. If you see the "slip" light flash, ABLS was engaged. This cannot be turned off.
It just got cold out...My truck is beeping at me and a (_) symbol warning light is on my dash. What is this?
This is your TPS or tire-pressure sensor. Odds are you need to air up for the winter.
I just installed an intake/stereo and Check Engine/Air Bag light came on...What the heck?
First, try doing the ECU reset above, if that doesn't work...figure out what the heck you did wrong with your install.
What's some random stuff I might not know
Hold unlock to roll down the windows.
Don't pull things in reverse.
Don't us 4x4 on dry pavement and don't do hard turns while stopped.
Tint scratches easily on the titan, clean your window cracks (especially the bottom) to minimize. 20% tint matches nice.
Stock speakers are 2ohm...and suck.
6.5" mounting depth is the VERY most you can ever hope to get for a sub under rear seats (more like 6").
Beware of backspace on your aftermarket wheels...the titans wheels are rather narrow and tucked in.
Changin the fluid in the rearend is easier than changing the engine oil.
The search button on titantalk works wonders...almost every question has been asked several times over.
2005 CC 4x4 SE,
Click Here for some useless Titan information from some idiot.
Adam AKA GoogleWhore™
Old people don't need companionship. They need to be isolated and studied so it can be determined what nutrients they have that might be extracted for our personal use.
Facts are meaningless. You could use facts to prove anything that's even remotely true! -Homer Simpson
adavis99 is offline   Reply With Quote
