New pics of sub box and amp install
Pics of sub box from tech12volt loaded with Punch Stage 2 DVC. Box fits exactly like it should. Subs fit like a glove too.
Amp install under the seat. I think it looks good enough. Let the flaming begin.
I did all the hooking up myself. Subs dual 4 ohm wired in Parallel = 2 ohm, from what I read. Amp Punch 500.2 250 watts RMS X 2 at 2 ohm. I used both channels as you can see from the picture. Friend said wire it Bridged, I said no way makes it a 1 ohm load from what I read again. Amp is only 4 ohm stable bridged. Figured I'd blow it up??
New Deck Pioneer 7800 is on the way.. Can't wait to hear tech12volt's box.
All this low voltage/ohm stuff is killing me.. I'm a lineman "high voltage electrician" used to working with 2400/4160V or 7200/12470V. I think I got it though.
04 is GONE.. White CC, SE, 4x2, Big Tow, Bed extender, Factory Bedliner, Splashguards, Pinstripping
Banks Monster, K&N FIPK, Extang Tuff Tonno, AVS Bug Deflector, AVS In-Channel Vent Visors, AVS Rear Window Sun Reflector, AMSOIL 5W-30, Differential-Royal Purple 75W90
Best 1/8 run 9.7239 @ 71.85 mph
1/4 run calculated conversion 15.13 e.t.
06 Black beauty, KC, SE, 4x4, Texas Edition
Gone!!!!!!!!!!!!!!!!!!!!!!! 15,000 miles
08 White CC, SE, 4x2, Factory tow hitch, Splashguards, 20% Tint, AVS Bug Deflector, Extang Tuff Tonno, AMSOIL 5W-30, 8000 Miles
Pioneer DEH-P7800MP, Rockford Fosgate Punch P5002, 2 10" Rockford Fosgate Punch Stage 2 DVC, Custom RF box built by Tech12volt.
