Re: 2007 XE Brake control wiring harness
If youhave the Tow Package, the harness will be in the glove box, or center console...If you don't, you can buy the harness adapter from Nissan, it plugs into the truck wireing harness just to the right of the steering colunm. behind that lower plastic dash panel. Your truck should already have the plug in the wire harness...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
