Interior trailer lights not working
My trailer has 2 dome lights that haven't worked since I got the Titan. Never really bothered me much but the Mrs. has been giving me grief about fixing it. So I've been doing some searching and am now totally stumped.
I've got the big tow, but checked to make sure relays #1 & #2 are there. I not only checked the 2 fuses above the accelerator, but EVERY fuse in the box behind the battery - everything is good. I'm using a voltmeter on the constant 12v of the 7-pin (upper right pin) and the 7-pin ground (lower left pin) and I ain't getting a damn thing. My ground is good cuz I'm getting a nice reading when I turn on the lights and hook the + up to the running light pin (upper left). I'm trying to remember when I hooked up my brake controller if there was an extra wire in there - I seem to recall that there was. Is there something you gotta do w/ the wire harness for the constant 12v?
Any other ideas?
I've got feeler gauge fingers, torque wrench wrists, and a timing light eyeball!
05 SE KK 4x4
offroad, big tow, buckets, util.
$$$ stereo
Pro Comp 6", Dre's/Bilsteins, PRG Traction Bars
315/70 17 BFG AT KO on 17x9 AR Chambers
