Old 01-02-2007, 07:45 AM   #14 (permalink)
PenguinLE
Re: PRG Minii Lift Post-install Question: HELP!!
As others had previously suggested it sounds like the shock may be spent.
In some cases, shocks will adjust over time to s pecific setup. If you change the height of the setup after the shock is settled in, then they can fail easily. It was always this way with non-coilover setups, so I assume the same logic applies in this case.
PenguinLE is offline   Reply With Quote
