Re: PRG leveling kit and Front axle strain
Originally Posted by PrerunnerGreg
The axles popping out is a pretty common problem on all titans and armadas, lifted or not. For some reason cold weather has somehting to do with this issue (wether it is the cold or just people using 4wd, im not sure). The circlips that retain the axle shafts fail or are undersized, usually the dealer will replace the complete front axle assembly. Again, it has nothing to do with any lift, as many, many stock trucks have this issue. Just one more thing nissan needs to add to the "fix it" list.
Great, just another thing I have to look forward to. First the rear end and now the front. Just don't trust this truck anymore. Got to start looking eslewhere.
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
