Re: How to install remote starter
I have the column shifter so mine was a little bit of a pain to get out but just be careful not to scratch anything like the instrument cluster and it you can work it out. Mine has the dimmer switch and cargo light switch in the upper panel that need to be pushed out from the front also. Next, take the four bolts that hole the instrument cluster out and just lift it out. Mine just has one wiring harness on the back that comes off by pressing the center of the plug and unplugging it. I started to go under the dash and hook all the wires up that way but there was no room or slack to pull the wires down. The same bundle of wires run right behind the instrument cluster. Carefully remove the wire loom and/or tape from the bunch of wires that have a heavy gauge green wire, brown wire, a smaller black/red, and a heavy red one
