Old 01-08-2007, 07:12 PM   #4 (permalink)
src4usarmy
src4usarmy's Avatar
Re: How to install remote starter
Check the big green wire and you should get 12 volts all the time on this one, this is the constant, this kit has two red wires from the remote starter that need to be hooked up to this wire, I also hooked up my power wire to the bypass module to this wire. There were two starter wires, a brown wire and a light green one, the starter wire from the remote start on this kit is yellow/black and needs to be hooked up to both of these. These will show 12V only when the key is in the crank position.
Next is the ignition wire which should be black/red and show 12V in the run and crank positions and a white wire from the remote starter gets hooked to this one. Next thing is a red accessory wire and a purple one. Hook the white/black wire from the remote starter to both of these.
src4usarmy is offline   Reply With Quote
