Old 01-08-2007, 06:17 PM   #5 (permalink)
src4usarmy
src4usarmy's Avatar
Re: How to install remote starter
Next look on the back of your dimmer switch which mine was in the upper dash panel and find the red/blue wire and hook up the brown wire from the remote starter to it if you get a positive reading when you turn your park lights on. Next take the lower platic trim that runs along the bottom of the door next to the driver seat loose by pulling up starting at the back of it and pull it toward the back, exposing a white plastic cover with fastners along both sides about every inch or so. Take a small flat screwdriver and insert it in each hole and pry up and toward the center of the white plastic cover to get them loose. I took about five loose on each side.
how-install-remote-starter-115_5958.jpg  how-install-remote-starter-115_5972.jpg  how-install-remote-starter-115_5973.jpg  how-install-remote-starter-115_5974.jpg  how-install-remote-starter-115_5979.jpg
src4usarmy is offline   Reply With Quote
