Old 01-12-2007, 11:07 PM   #4 (permalink)
Yellomantis
Yellomantis's Avatar
Re: Tire Pressure sensors, aftermarket rims
Originally Posted by Just-in
makes sence thanks, so you can use them with aftermarket rims & tires, but do you need the computer re-flashed or anything to recognize the new pressures? and hows the sensor connect to the computer?
You can use them with most aftermarket wheels. Just gotta make sure: 1. the valve stem hole is on the face of the wheel, 2. the "nut" portion of the sensor can physically seat in the hole provided. No "re-flash" required, you're just moving from one wheel to another.
www.myspace.com/yellomantis
