Re: Which one Fabtech or Procomp?
Pro Comp is straight bolt on, Fab Tech has some grinding/cutting involved up front. Not exactly sure of what since I went the Pro Comp route. Both have blocks in the back. Either one you should think about getting the 2 1/2" leaf pack and eliminate the block. PRGproducts.com has everything you need. So I think the Pro Comp would be the eisier of the 2.
06 6 inch lift on 35's and more
