Old 01-19-2007, 07:25 PM   #30 (permalink)
blueskys
blueskys's Avatar
Re: Best helper springs for ride and hauling?
Originally Posted by SirStrider
Does it use airbags? 2 or 4? How do they hold up - sounds like a nice system. I need some work on mine for sure - looking at sway bar, traction bars, everything. Just put a Timbren SES on as an emergency patch for my long trip - I'm on vacatation. Seems to help with load, but not with axel wrap.
I also have a heavy ARE shell on my KC Titan. I installed the RM active suspension to help with the sag when fully loaded with dive gear. It works. It works well without a compromise in ride quality. The kit preloads your leaf springs and adds capacity to absorb the little bumps without rebound. This makes for a smooth ride. What other kit can you buy that increases capacity and ride quality?
The are no airbags. It is a coil spring that is adjustable to suit your needs.
2007 Pewter Metallic SE King Cab, O/R Wheels and Tires, ARE Z Series Shell, Bilstein 5100s, 51,000 miles on Mexican Sonoran back roads in search of the elusive Sonoran lobster.
blueskys is offline   Reply With Quote
