Re: SURVEY: Front Differential Problems
I also came up with an alternative. Once I get the diff replaced (still gotta do this since my splines are trashed), I'm gonna see if I can get Curtis or somebody to drive a pin throught the shaft in the retaining ring area. Seems like that would solve the problem. Might have to drill/tap a couple plugs on the diff housing for access to the pin during assembly/disassembly.
I've got feeler gauge fingers, torque wrench wrists, and a timing light eyeball!
05 SE KK 4x4
offroad, big tow, buckets, util.
$$$ stereo
Pro Comp 6", Dre's/Bilsteins, PRG Traction Bars
315/70 17 BFG AT KO on 17x9 AR Chambers
