Re: i have found the reason i have burnt up 4 diffs
I would blamee it on the techs not setting up the rear end correctly and your correct about the rear specs of your alignment. It is possible that there is something bent or was manufactured off spec. I wold have someone measure the actual diff housing and see if its bent. Your alignment in the rear should not be that far off.
