02-15-2007, 07:33 AM
#2
Cont'd: Fog Light Mod - On with or w/o parking lights - simple
My final picture of my fuse box looked like this:
{{ See Pic6.jpg }}
Put the cover back on the fuse box. I put the fuse back in the fuse slot in the box.
Now for inside the cab. I will mostly cut/paste from JustIntoxicated’s instructions from here. It is the same...
1) Remove lower Dash (2 screws and pop the clips out by kind of pulling upward) (this will make the mod easier). You may have to unplug some connectors if you have a rear power window, adjustable pedals, and/or the backup sounders.
2) Remove plastic around steering wheel (3 screws and some clips)
3) Remove Bulb Stalk (white clip on top and bottom and it unplugs like a nintendo game)
4) remove black casing from bulb stack (it is attached in 3 places by tabs, be careful it's expensive)
5) Cut wires as shown below and follow the diagram.
When you run the wire to the stalk, you will solder one side (doesn’t matter which) to the wire going to the fuse box. Solder the other to another wire. The other end needs a connector and needs to be grounded as shown.
{{ See pic7.jpg and pic8.jpg }}
Button her up and put everything back together. If you used smaller than 18ga wire, this should be easier. I wouldn’t use anything smaller than 22ga. It doesn’t take much power at all to throw the relay, but you do want some type of durability.
Note: When you put the plastic back over the steering column, be careful - it's a tight fit and I tended to pinch the wires.
