Re: Rockford HU LOC Wiring Diag / write up
If anyone is shy about yanking the bezel and radio to get a 12v accessory line, I tapped into the cig lighter for the rear console. There are 4 screws to remove from the compartment that is your center console and then you have easy access. Plus, there is a little less distance to run the 12v wire.
If it's a penny for your thoughts, and you give me your two cents, what happens to the other penny? Taxes, the Democrats tax everything!
Robert Holmes
2005 Titan LE Crew Cab 4x4
Glacier White
Big Tow
RollBack Tonneau Cover
Aftermarket Nav
AVS Bug Shield
6000k HID Conversion
AEM Brute Force Dry Intake
Navone LOC NE-774V ( http://www.davidnavone.com/cart.asp?14&pid=155)
Tech12Volt 12in Box
1 12in Boston Acoustics G1 Dual 4ohm Subwoofer
Rockford Fosgate P3001 Mono Amp (300watts rms x 1 at 2ohms, 150watts rms x 1 @ 4ohms)
